Calgary deep freeze!
- Golf Cart
- Vehicle: 1992 Exceed
Re: Calgary deep freeze!
The Temro 310-0051 has been discontinued. but if you can find it grab 2. That one was suppose to be brass.
All that Temro has is the 310-0049 steely ( $26.00 at Lordco)
- Vehicle: 1993 Delica Exceed
Hello all. I am a newbie here but thought I might chime in on this subject. To give you some background, I'm not yet a delica owner but hope to be soon. I do however have some experience with diesel engines and have some advice for our cold calgary winters.
The best thing you can do is change the Engine oil. if you are still running with a 15W40 or 10W30 at -35 you are just asking for trouble. If you want a detailed explanation email me, but needless to say it is like trying to start your engine with tar. What I do, and my company does on all of our equipment in the winter, is use a 0W30 synthetic oil. we actually run this all year round in some applications. Hope that helps. and feel free to email me if anything is unclear.
I'm driving the deli to Calgary on thursday and hanging around for a couple weeks (let me know if you want to meet for a coffee/beer). Hoping for an uneventful journey out there and hoping I can get the engine started once I'm there.. it doesn't sound like I'll have access to a garage so I'll be parking outside.
I've got fresh fluids (15w40
)and filters, a new optimum battery, good glow plugs. Has been starting instantly in -10 last few mornings on first crank with only one cycle of the glow plugs. So hopefully I'll be able to convince it to start in calgary for the next couple weeks?
I'm going to bring along a battery charger and lots of extension cord, I think if I leave it on the 2A trickle charge overnight on cold nights that will keep the battery topped up and warm and increase my chances of getting going
RCFA is right on the money.coaxial wrote:I'm driving the deli to Calgary on thursday and hanging around for a couple weeks (let me know if you want to meet for a coffee/beer). Hoping for an uneventful journey out there and hoping I can get the engine started once I'm there.. it doesn't sound like I'll have access to a garage so I'll be parking outside.
I've got fresh fluids (15w40)and filters, a new optimum battery, good glow plugs. Has been starting instantly in -10 last few mornings on first crank with only one cycle of the glow plugs. So hopefully I'll be able to convince it to start in calgary for the next couple weeks?
Keep the filter, drain 15w40 and toss in 6.5 liters of 0w30.
Aside from the block/oil pan heater, it's one of the best things for your 2.5 under -10 cel.
Hey I just found a link on youtube that kind of illustrates what i'm talking about.
try this link: http://www.youtube.com/watch?v=zFmJh9l4MXw
or just search Castrol Edge Oil cold temperature testing.
One thing to note is that it doesn't give the grade of the "synthetic Oil." From my experience that looks something like a 10W30 or even a 5W30. Even though this test is being done at -52 degrees, it is a very close comparison to what is happening at say -30 in your engine.
no idea on the timing, but that sounds like a great idea!I'm driving the deli to Calgary on thursday and hanging around for a couple weeks (let me know if you want to meet for a coffee/beer).
- wookie
- Vehicle: 1993 Exceed
Hey I'm heading out on Friday! With fresh 15W40
- CrazyFamilyof5
- Vehicle: 1991 Exceed Green/Gray crystal lite
Block heater Napa # 605-3509 OR Temro # 310-0051
My local Napa only had the 605-3032 in stock so picked up that one yesterday. Thank you wookie & snelson for getting the part numbers. Now just need to get it into Kirkham to be installed and I am going to see about the 0W30 synthetic oil.Napa 605-3032
After sitting outside in the wind since Fri, I was able to start it with not too much effort yesterday afternoon and this morning. Tomorrow maybe a different story (-24).
- White Mule
- Vehicle: 1991 Delica L300
Block heater? $30.
Install? $100.
Plan coming together in adverse conditions?
You guessed it.
PRICELESS
Cheers for the help.
Install? $100.
You guessed it.
PRICELESS
Thanks,
White Mule
White Mule
$100 at a shop? that is a great price.. where did you get it done?
- CrazyFamilyof5
Yes where?? Best I estimate I got was Kirkham at least $220 if not more
I'll need some sort of solution.. the drive to calgary was good yesterday (despite seeing about 30 accidents along the way) but I parked outside overnight and now she won't start :(
charging the battery now to give it another try, but it looks like I'm stranded.
Pulled the fuel line and the primer on the filter pumped some out so I don't think the fuel is frozen (lots of additive in it) but it is real slow to crank over and won't fire. Clutch and shifter are very stiff too.
your oil is too thick.but it is real slow to crank over and won't fire.
There's only one solution, heat. you have to get some heat in to it. if you have a block heater, plug it in for a couple hours, if you don't... well, people have used all sorts of heat sources under their engines or in the engine compartment... simple ones include 100w light bulb in the engine compartment, more risky ones include camp stoves under the engine...
perhaps the "proper" solution would be a magnetic oil pan heater... not nearly as good as a block heater, but does do some good in a pinch.
hmm even jump starting didnt get it going.. cranked and cranked and no go. Little puffs of black smoke from the exhaust, but very little. I'm going to try and figure out how possible/expensive it will be to tow it somewhere warm to thaw it out and figure out the problem. Could be the fuel.. although I was able to pump a bit of it, it was very syrupy. Could be the glowplugs. And yes the oil is too thick. As soon as it is running I'll change it to syth 0w30 or similar.
I'm in Mayland Heights if you have any advice for a garage or something. Thanks!
do you have any form of heater on it? even a magnetic oil pan heater is something....
