FIXED: Sliding Door is not latching. What is the purpose of that motor?
TRUTHautomotive
Vehicle: Delica L400 High Roof
Post by TRUTHautomotive »
So this happened.
I removed the panels on the sliding door and found that the rear latch has some sort of motor attached to it. I disconnected the lever from this motor and voila the door latches fine, power locks still seem to work.
I am usually all for deleting unnecessary electrical components and would be satisfied leaving it disconnected, but usually it isn't a bad idea to figure out what it actually does...
Can anyone shed some light on this? I will post a photograph tomorrow morning for clarity.
Last edited by TRUTHautomotive on Thu Mar 31, 2016 8:46 pm, edited 1 time in total.
TRUTH Automotive Services
General and JDM Maintenance in Calgary AB
Mr. Flibble
Re: Sliding Door is not latching. What is the purpose of that motor?
Post by Mr. Flibble »
When the contacts on the door close, the motor starts up and pulls the door inward. This allows you to close the door very quietly and without slamming it.
Often the contacts get dirty where the door closes, and if you clean them the motor starts working again.
TRUTHautomotive
That is exactly what the situation was. Fixed!
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: FIXED: Sliding Door is not latching. What is the purpose of that motor?
Post by Big-Bird »
Same advice I gave you in a PM so at least we're consistent. Aside from your youngster's bedtime hopefully you can show up with your buddy and your Mitsubishi!
A&W food is good.....peppered bacon on a sirloin burger.....(slobber.....drool).
frostyfriday
Vehicle: 95 Delica L400 swb
Post by frostyfriday »
Can you perhaps give me some insight as to how you removed the sliding door trim?
-Dennis
Return to “L400 Technical”
