So I installed, or clipped on, a magnetic oil pan heater. I must say, when it drops around -20 it doesn't work to save its life.
I went to get a circulating coolant heater installed in the rad hose but apparently there is a problem with a valve? It would normally be installed in the lower hose, but after mine was installed this "valve" wouldnt allow the warmer coolant to circulate like it should, making it basicaly usless. So as of now I still only have the magnetic oil pan heater. Good thing it usually hovers around -5 or -10 here. Any insight or suggestions would be appretiated. Has anyone installed a block heater where the frost plug goes? If so does it fit proper? What part numbers?
Josh
Block Heaters
- Vehicle: L300 poptop gasser
I installed the stick on type oil pan heater. It got my van started at -26. Got it at canadian tire for $120. I also bought new batteries as mine were the originals from mitsubishi with japanese writing on them.
haven't had to use it below 30 below because it just hasn't gotten that cold. But from my point of view it really does work.
http://canadiantire.ca/browse/product_d ... earch=true
that is the best I can do. Although I called and just asked for one of the stick on polar pad oil pan heaters and was told they had them before I went in. Maybe I am just in a colder climate and therefor the store carries them whereas other stores may have to order it.
I could drag one home from here if you really can't find one. But if you live in Burnaby and aren't out of the area too much I don't know if its necessary
