Do i have a cooling isssue?
shaner
Vehicle: L300
Post by shaner »
So I noticed my egts doing something a little funny
after driving around shortly I notice that the egt's stay around 4 or 500 even when I am stopped. should they not drop right down?
I do not drive fast and I usually keep them around 900 and never over ten except for very short time periods. I just had the water pump and timing belts (as well as a new head) replaced last month.
what can I check to make sure my vans cooling system is working properly?
is doing the rad a big job?
thank you
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Do i have a cooling isssue?
Post by thedjjack »
Normal... as you drive the exhaust heats the manifold, turbo and pipe.... that is going to be 350-500 just running....
I would wait for temps to come down to 400ish before shutting down...
shaner
Vehicle: L300
Post by shaner »
that would seem to make sense. but I never really acted like this before.
does anyone know how to test if the fan clutch is not working?
thedjjack
Post by thedjjack »
cooling system is water temperature (rad, fan etc)
EGT is the flame out the cylinder and heat in the exhaust manifold..
higher than normal temperature could be fuel/timing issues....or headwind :)
