lap belt seatbelt replacement
hesser
Vehicle: 94 l400
Post by hesser »
Hello. As others have experienced, my lap belt is no longer disengaging on one of my middle passenger seats. Its racheted all the way in and wont release. It appears that the small plastic enclosed ratcheting piece has broken. It also appears that the seat belt mechanism is held on by one bolt. Has anybody replaced their seat belt unit? Is that simple?? I don't see a way of fixing this as it appears as though the broken pieces are pretty small little pieces of plastic. I am concerned about this as it will be buckling in my children's car seats. Thanks for any help you can give.
Mike
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: lap belt seatbelt replacement
Post by Big-Bird »
When it comes to safety its best to replace the offending part. There was also an L400 owner who has been parting out his busted Delica. You can always get a part shipped to you from guys like RSI or Amazing Auto.
hesser
Vehicle: 94 l400
Post by hesser »
I have contacted a couple people, waiting to hear back. I've also received a message from a local Deli dealer. 150 dollars each. I guess you can't put a price on safety.
Big-Bird
Post by Big-Bird »
If you have some time a stroll through an autowrecker might yield some value.....Mid 90's Dodge Colt uses the same headrest frame as the L400 so it might be possible that a lap belt from the back seat might work. The Dodge colt is made by Mitsubishi incase you didn't know. There are several legacy parts that were used in multiple models of Mitsubishi around the world.
8-)
psilosin
Vehicle: L400
Post by psilosin »
While doing a spring clean today noticed that my stuck lap belt has started working again...guess that drivetrain vibration must have wiggled it just right over the last few months :o
nxski
Post by nxski »
psilosin wrote:While doing a spring clean today noticed that my stuck lap belt has started working again...guess that drivetrain vibration must have wiggled it just right over the last few months :o
One of my captains chairs does that. It works for a few weeks, then stops working for a few weeks.
CREGAN
Post by CREGAN »
My drivers rear captain seat lap belt decided to stop working today. So I took it off and decided to take a peek. Nothing broken or floating. So I then decided to take off the passenger side one that works to compare and now they both don't work!! Anyone got any suggestions? This van pisses me off sometimes (actually a lot).
Craig
Return to “L400 Technical”
