L400 Front and Rear Axle
- lettereleven
- Vehicle: L400 Super Exceed
I've got a complete front and rear L400 axle.
Before I take it completely apart, I thought I would put it out there.
If you are interested in anything in the picture, just give me a shout.
Depending on the part, a very nominal cost recovery would be appreciated.
Jamie.
Jamie.
- IMG_1682.jpg (24.61 KiB) Viewed 4375 times
Re: L400 Front and Rear Axle
Is the differential an LSD or conventional? If LSD I'm interested. PM me pls with the price.
thx
TLGF
thx
TLGF
- lettereleven
I will check it out and let you know.
- lettereleven
Its an OPEN Diff.
- CREGAN
Jamie- why do you have these? Something wrong with Blueberry or did you just run into a deal you couldn't refuse?
Craig
Craig
- lettereleven
Well, I went to buy a wind visor. Then I poked around a bit and saw a nice set of sway bar links (i noticed the boots on mine were toast last week when changing the bushings). For a bit more, I could have the whole sub frame.
Eyebrows were raised from onlookers as I wheeled massive sections of van anatomy up the elevator into my apartment.
- CREGAN
That is funny. Sounds like it could be something Kramer would do on Seinfeld.lettereleven wrote:Eyebrows were raised from onlookers as I wheeled massive sections of van anatomy up the elevator into my apartment.
- Vehicle: 90 5spDelica, 93 2.8 5speed SWB Paj
I have not tried personally, but I believe the half shafts would fit my 2.8 paj. One of my CV joints is clicking away, so I should probably replace it before it breaks on me. If you don't mind parting things out, and no one wants the entire front setup. I'll check which side I need, perhaps both. I'm in no hurry though, so if someone else calls for them...
It would perhaps be helpful to your cause of selling these parts if you listed the gearing.
- lettereleven
Great - just let me know which side(s) you need. I will hang on to them or let you know if someone else is interested.
In terms of gearing (at least for the rear) its a bit irrelevant as I dumped it at Ralph's this afternoon. There wasn't much of value on it and my building manager was quite (very) upset with me for leaving van parts in the parkade.
J
J
Sorry for not getting back sooner, I might as well just grab both sides. What kinda price are you thinking??
- lettereleven
Pm sent
