All the relays and switches light up and click away nicely but when I blow through the valves to test which port is open when a current is applied, neither one is doing anything. The valves just don't appear to work anymore. Only the negative (no current) port is open.
Am I missing something here? I checked with a meter to confirm that there is current going to the valves but nothing is happening inside.
One of them was exposed a short time post crash to some battery acid... but it didn't touch the valve (noticeably), just corroded the bolts going into the side of it. I don't see any reason they shouldn't work.
Anyone else had experience with these or have any ideas? They are grounded well and look good but nothing happening. 2 of them. Used for one month or 2 in total. AndrewH kit.
Thanks, Duncan
BRING ON THE WINTER!
