So I'm gonna do the timing belt job at 120,000km as advised. Should the radiator usually be changed at that point? I believe it is the original copper one. How long do they last?
Thx
Delica L300 Radiator....
- Vehicle: 1996 Delica L300
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Delica L300 Radiator....
KEEP THE RADIATOR
take it too a rad shop and have it cleaned the new plastic aluminum rads are not as good.
- Rising Sun Auto Import
Pros & Cons for each type.
http://www.caparadiator.com/aluminumvscopper.html
Late model L300 have used aluminum, right?
Steven
Steven
- thedjjack
I would take an aluminum rad over copper...
but we are talking about a PLASTIC end tank radiator and not a true aluminum rad..sorry article does not compare the aluminum radiator you are getting
plastic tanks eventually leak at the joint, plastic tanks cannot be repaired by a rad shop (remember delica rads are not as easy to find on the road).
copper can be fixed by any rad shop, even the owner in the bush...
weight??? delica = race car?? I take a weight penalty for a radiator that can be serviced..
- bionic
- Vehicle: 92 delica exceed
...second the Jack, the plastic tank units are good for a few years....maybe:( Recore by a reputable rad shop is the best option.
Rad weight?..really???...ha, ha, ha, ha...
