smoke from turbo
- Vehicle: L300 1994
smoke from turbo
I just changed the head the engine sounds good when idle but when i push the throttle there is no power. There is coming smoke from the turbo exhaust part. no leaks. Any tips?
- Vehicle: delica L300
Re: smoke from turbo
Is your egr stuck open is your waste gate stuck open. Does your turbo impeller when turned by hand turn very easy?
Dustin
Dustin
how do i inspect if the egr or wastegate are stuck?
