let's see what kind of flex your Delica's got !!!!
Posted: Thu Jan 06, 2011 10:30 pm
Like the title says.. these are 4x4's ... show your Delica's flexing !
All form of Delica's welcome
Re: let's see what kind of flex your Delica's got !!!!
Posted: Fri Jan 07, 2011 1:10 am
by nxski
What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli...
Posted: Fri Jan 07, 2011 7:41 am
by jaggedfish
My recently sold L300 before it was lifted. About the maximum articulation possible. This was at Stave Lake, BC...
Blue Gene above Stave Lake
Articulation - web.JPG (61.36 KiB) Viewed 6854 times
My new L400. Not so much "flex" but showing maximum departure angle or backwards approach angle depending which way you are driving Taken over the Christmas holidays in Sechelt, BC
Zevra above Sechelt, BC
IMG_2524 - Copy.JPG (251.5 KiB) Viewed 6854 times
Tons 'o' fun!
Posted: Fri Jan 07, 2011 8:33 am
The Miss Lil' Bitchi:
Added leaf spring and re-indexed torsion bars amounting to one and one half inch lift but still with stock anti-sway bars (stablizers).
Posted: Fri Jan 07, 2011 9:51 am
nxski wrote:What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli...
Just a 2" lift with 31" tires
Posted: Fri Jan 07, 2011 11:15 am
by delicat
Nice flex on the rear guys, still trying to find it at the front though...
Posted: Fri Jan 07, 2011 11:58 am
by thedjjack
Delica's have Flex?? You sure?
Here is a picture of mine pre-me owning it showing off it Flex.
This is bumper flex! (This is why mine has the bed slide and tire moved behind the back axle).
Posted: Fri Jan 07, 2011 1:34 pm
by thelazygreenfox
That flex and departure angles has me wondering where I should install extra back up lights on my L400. Looks like they'd be torn off under the rear bumper. Any ideas??
Wayne
TLGF
Posted: Fri Jan 07, 2011 5:37 pm
by DelicaMark
Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give!
IMG044 (640x480).jpg (222.57 KiB) Viewed 6747 times
IMG045 (640x480).jpg (262.14 KiB) Viewed 6747 times
Now for $1 can anyone guess where this was. Hint #1 is that it is in the Southern Vancouver Island area.
Looking Eastish
IMG046 (640x480).jpg (209.84 KiB) Viewed 6747 times
Looking Westish
IMG047 (640x480).jpg (229.5 KiB) Viewed 6747 times
-Mark
Posted: Fri Jan 07, 2011 7:20 pm
by Jordan
thedjjack wrote:Delica's have Flex?? You sure?
Posted: Fri Jan 07, 2011 8:06 pm
by thedjjack
Jordan wrote:
Did you find that gem after the purchase?
No I saw it during negotiations help with the price. There was no real damage other then bent bush guard and a dent in the bumper. Frame ect... all fine.
Posted: Fri Jan 07, 2011 9:39 pm
by nxski
Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excited
Posted: Sat Jan 08, 2011 2:07 am
jfarsang wrote:Just a 2" lift with 31" tires
nxski wrote:Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excited
Roger that.
Posted: Sat Jan 08, 2011 10:10 am
by Kuan
DelicaMark wrote:Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give!
Looking Eastish
Looking Westish
-Mark
Road between Lake Cowichan and Port Renfrew??
Posted: Sat Jan 08, 2011 1:09 pm
by delicat
Here's a few pictures of my old beloved Mitsushi showing off her flex and departure angle.
And who ever said Falco was hard headed was quite right indeed!
Flex 1.jpg (105.23 KiB) Viewed 6616 times
Departure angle.jpg (101.95 KiB) Viewed 6616 times
And here's a few from a L400 while on one of our outings:
Flex 2.jpg (102.29 KiB) Viewed 6616 times
Flex 3.jpg (89.73 KiB) Viewed 6616 times
As you can see there's almost no flex at the front...
