Cylinder head complete from Hyundai , all engine parts
Posted: Mon Aug 09, 2010 12:22 am
Assiniboine has 4D56T cylinder head complete and all engine rebuilt parts from Hyundai.
All are OEM.
1. cylinder head complete ; $1400
2. cylinder head only ; $800
3. In addition to those, we supply camshaft $120 , camshaft sprocket $30 ,front bearing cap $70 , head gasket $120 , intake valves (4) ; $100 , exhaust valves (4) ; $100 , intake rocker arms ; $30 , exhaust rocker arms ; $30 , injector nozzle tip gaskets( set of 12 ); $40 , fuel return pipe gaskets ; $30 ,clutch fan assembly ; $160 , crankshaft(standard) ; $700 , key-crankshaft ; $20 , head bolt ;$15, crank pulley ; $ 180 , balanceshaft sprocket ; $40 , balance sprocket washer ; $30 , crank shaft sprocket ; $ 40 , main bearing set ; $190 , head gasket full set ; $290, half gasket set : $ 100, crank shaft seal ( front and rear ) ; $50 , connecting rod bearing set ; $60 , transmission ( used ) ; $1600 , cylinder block ; $900 , radiator ; $250 , alternator ; $290 , starter ; $290, new injector with 3 heatshields ; $110, turbo ( new ) ; $1100, glow plugs ( set of 4 ) ; $120 , etc( camshaft holding cap, various washer, adjusting, stud, seals..... )
If you need any particular part, pls call or email me.
I will send you the full diagrams for you to choose.
Steven
japancarexpress@gmail.com
778-995-2459
All are OEM.
Steven
778-995-2459
