Cylinder head complete from Hyundai , all engine parts
Rising Sun Auto Import
Assiniboine has 4D56T cylinder head complete and all engine rebuilt parts from Hyundai.
All are OEM.
1. cylinder head complete ; $1400
2. cylinder head only ; $800
3. In addition to those, we supply camshaft $120 , camshaft sprocket $30 ,front bearing cap $70 , head gasket $120 , intake valves (4) ; $100 , exhaust valves (4) ; $100 , intake rocker arms ; $30 , exhaust rocker arms ; $30 , injector nozzle tip gaskets( set of 12 ); $40 , fuel return pipe gaskets ; $30 ,clutch fan assembly ; $160 , crankshaft(standard) ; $700 , key-crankshaft ; $20 , head bolt ;$15, crank pulley ; $ 180 , balanceshaft sprocket ; $40 , balance sprocket washer ; $30 , crank shaft sprocket ; $ 40 , main bearing set ; $190 , head gasket full set ; $290, half gasket set : $ 100, crank shaft seal ( front and rear ) ; $50 , connecting rod bearing set ; $60 , transmission ( used ) ; $1600 , cylinder block ; $900 , radiator ; $250 , alternator ; $290 , starter ; $290, new injector with 3 heatshields ; $110, turbo ( new ) ; $1100, glow plugs ( set of 4 ) ; $120 , etc( camshaft holding cap, various washer, adjusting, stud, seals..... )
If you need any particular part, pls call or email me.
I will send you the full diagrams for you to choose.
Steven
japancarexpress@gmail.com
778-995-2459
Re: Cylinder head complete from Hyundai , all engine parts
Pic for Cylinder head ( 4D56T )
You may need valve seats(intake and exhaust).
Steven
Pics for complete cylinder head(4D56T) from Hyundai.
For more info, contact us.
Steven
shop 007.JPG (124.79 KiB) Viewed 1558 times
shop 006.JPG (134.94 KiB) Viewed 1561 times
