EGR Plates
Posted: Fri Jan 06, 2012 11:01 am
I know this is a not the greatest Sketch.....But here is a pattern for EGR blanking plates.
Cheers!
Cheers!
Forum for Mitsubishi Delica owners and enthusiasts.
http://delica.ca/forum/
I think that's a good idea. I originally used a mild steel plate between the EGR and the intake. One day I was climbing out of Kamloops toward Merritt and I noticed a significant lose in power. When I got back to Van I opened everything up and the bolts holding the EGR onto the intake just slid out with the threads from the receptacle still wrapped around them. I had read about galvanic reaction but I never thought that it would really happen to me. In the end I had a quarter inch plate of aluminium welded over the EGR mount on the intake.dennis_lambert wrote:It was Drawn on a napkin sitting on a Stump,with pale ale in one hand...Windy day,raining ...up hills...
I will work on a better Drawing to replace the knapkin sketch while I am stuck in the office under soul sucking flourecent lighting and no windows..
Oh yeah ...The first plates I made were made out of 1/4 normalized plate steel.The next batch (if I ever get around to it) is the same,with the exception of the plate on the cold side, its will be now made from 1/4 thick Alum.
There should be a gasket between the plate and the manifold, old or new. If the old one is baked on the EGR side and you can't remove it or is butchered, you can get exhaust gasket patch material at Lordco and cut it to fit = no problems. If the gasket is baked on the manifold side but still has material all around, that will work fine as well.dennis_lambert wrote:Even a thin gasket between will substantially reduce the long term effect.
Cheers!
