y
Posted: Fri Feb 25, 2011 6:12 pm
by deli1733
7
Re: Running rough and making weird noise
Posted: Fri Feb 25, 2011 10:02 pm
by Luna-Sea
Simple stuff first,I would check the fuel filter,
use the drain and pump on the housing in
the morning see if any poop or water come out.
If you have not changed it in a while just swap
it out,eliminate a variable.
Good Luck
Let us Know!
Right On!
Posted: Fri Feb 25, 2011 10:16 pm
Might check the air filter, too. Not enough air and the fuel starves.
Posted: Sat Feb 26, 2011 9:55 am
by deli1733
I
Posted: Sat Feb 26, 2011 12:41 pm
by snelson
I'd be concerened with the whining sound and esp. the vibrations - I suggest a check of your belts esp the timing and balancer belts. Pop the 'hood' and remove the plastic belt cover for a look-see.
There are stories of balancer belts breaking, then f-ing up the timing belt in turn pooching your entire engine.
Posted: Sat Feb 26, 2011 1:36 pm
by deli1733
Y
Posted: Tue Mar 01, 2011 10:10 pm
by deli1733
I
