y
deli1733
Vehicle: 1991 L-300 94 Pajero LWB
y
Post by deli1733 »
7
Luna-Sea
Re: Running rough and making weird noise
Post by Luna-Sea »
Simple stuff first,I would check the fuel filter,
use the drain and pump on the housing in
the morning see if any poop or water come out.
If you have not changed it in a while just swap
it out,eliminate a variable.
Good Luck
Let us Know!
8-) Right On!
Might check the air filter, too. Not enough air and the fuel starves.
deli1733
Post by deli1733 »
I
snelson
Vehicle: 92 Delica Exceed
Post by snelson »
I'd be concerened with the whining sound and esp. the vibrations - I suggest a check of your belts esp the timing and balancer belts. Pop the 'hood' and remove the plastic belt cover for a look-see.
There are stories of balancer belts breaking, then f-ing up the timing belt in turn pooching your entire engine.
deli1733
Post by deli1733 »
Y
deli1733
Post by deli1733 »
I
