Inside temp not working
Posted: Thu Nov 25, 2010 12:03 am
by gramadin
Hi,
my inside temp gauge is not working, it is blinking EO.
I did my research and is most likely thermistor not working, which is easy to change,
but only if you can find it.
Does anybody know where can I find one on the continent?
Re: Inside temp not working
Posted: Thu Nov 25, 2010 12:09 am
by nxski
I have the same problem, mine is listed as a steady -E though. Sorry I can't help but I'm looking forward to seeing what the problem is.
Posted: Thu Nov 25, 2010 10:40 am
by Profister
In most cases the culprit is the loose/broken connection to the sensor; check the wiring. :M
Posted: Sun Nov 28, 2010 8:36 pm
by Raule Duke
the thermistor is attached to the little one inch square metal plate under the steering column.
Posted: Sat Dec 11, 2010 8:09 pm
by gramadin
Thanks , I know where to find it in the car, I meant where to find a new one locally. English is not my first language 8-)
Any ideas?
Posted: Sun Dec 12, 2010 11:01 am
by RichD
You can have the sensor from my van. It's not being used.
Posted: Sun Dec 12, 2010 7:22 pm
by gramadin
I would love to have it only if you dont use it.
I will send you pm.
