Regina Mechanic?
- Vehicle: Delica
Regina Mechanic?
Hi I am a proud new owner of a Delica L300 Exceed. I know there is a couple other Delica's burning around town, does anyone know of a good mechanic that can be trusted? Thanks :)
- Vehicle: 93 Exceed
Re: Regina Mechanic?
Knoll,
We have used Performance Auto (just west of Albert on 9th Ave.) Herman and his group have treated us well. Albeit, all we have had done is routine service and a block heater installed. Ours was the first Delica they had seen and worked on but were not intimidated in the least.
Rod
Rod
- Tinytoy
- Vehicle: 90 Suzi Carry, 91 Safari
Welcome to the club!!!
Don't know any shops in Regina, but have heard good things about Prairie Auto Haus in Saskatoon!
Happy trails and thanks for expanding the ranks of toasters on wheels here in Saskabush!
If at first you don't succeed , get a bigger hammer.
Which model block heater did you get and where?drrod wrote:Knoll,
Rod
Todd
Here is a thread discussing block heaters, etc.
http://www.delica.ca/forum/calgary-deep ... -4318.html
Block heater numbers:
Napa # 605-3509 OR Temro # 310-0051
There is another Napa number 605-3032.
I can't remember which Napa one we have but it sure works good. No issues starting if plugged in, even down to the - 30's.
Rod
Rod
Thanks. We have a couple NAPAs here!
I was thinking of getting the magnetic one from Canadian Tire but it just seems so weak.
Todd
Todd
- Firesong
Canadian tire has them and so does partsource.
That's where I got mine and it works really well.
If you do it yourself make sure you use a gasketmaker
goop that is meant for thermostats and stuff.
It hardens really hard and makes for a good seal.
My L300 starts at colder that -30 easily.
Piece of cake when plugged in.
FS
FS
Napa and Lorco have the right ones in. $35 at Lordco and $40 at Napa.
The magnetic heater is out of stock at every Canadian Tire in the Lower Mainland. It was $50 but unlike the internal ones, no installation costs.
- Firesong
Magnetic aren't the same as an internal block heater
but to each their own.
I used a magnetic oil pan heater before the internal
block heater was put in by myself. Then I used both.
Block heater is the cat's meow.
FS
FS
- Vehicle: Delica
Thanks guys! I love driving my Delica.
I also have a oil pan heater, it works good but I got my batteries tested today and I need 2 new ones. I went to National Battery and they are installing them tomorrow morn. I also bought a inline heater that I have not installed yet. Once that goes in, I am sure I will have no problems.
Happy driving.
Happy driving.
Yeah I know the magnetic heaters arent the same but for those looking for a cheaper alternative in a slightly warmer climate of the Vancouver area, this might be an alternative. Except there are none around. $50 with no installation (mag heat) vs $35-$40 plus cost of installation (block heat), anywhere from $100 to $220.
As for the 0w30 synthetic oil, has anyone found any in Vancouver and if so, where!? I saw the Can Tire brand that just said "30" on the bottle, but not sure if thats the same and its not synthetic.
- Firesong
I thought we were talking about Saskatchewan
My mistake.
In Saskatoon I run 0-40 synthetic blend
block heater (installed myself) and have a magnetic
pan heater which is epoxied on.
FS
My mistake.
FS
