TX-1 lightweight offroad rims - Group buy?
Posted: Sun Aug 29, 2010 7:59 pm
I'm going to order rims from Australia and want to see if anybody else out there is interested in getting a set too. These rims are bullet proof and have a similar strength than steel rims but still are relatively light weight. Load rating is 3000lbs per rim. These are the replacement of the legendary Outback TX-1 rims, which got used a lot for offroad racing, but not available anymore. They are in my opinion the best affordable offroad rims for Delicas. Steel rims are too heavy and take too much power away but regular street alloy rims a prone to crack if they get abused offroad.
http://www.performancewheels.com.au/industrial.asp
They are available in silver, black and in white.
So far I asked for these common sizes, but there are more available.
15x7
6 on 139.7
-4mm offset
8.6kg
67mm to 108mm hub bore
AU$90
16x6
6 on 139.7
-6mm offset
8.8 kg
67 to 108mm hub bore
AU$120
16x7
6 on 139.7
-4mm and +4mm offset
9.07kg
AU$120
The rims itself are actually not expensive, but obviously the shipping is not cheap. It depends how many people are interested. If we order two sets, the shipping would be around AU$240 per set, but if we order three or more we can bring it down to below AU$200 per set.
So what do you guys think? Anybody interested?
15x7
6 on 139.7
-4mm offset
8.6kg
AU$90
16x6
6 on 139.7
-6mm offset
8.8 kg
AU$120
16x7
6 on 139.7
9.07kg
AU$120
