Pulsating / vibrating brakes - check your sliding pins
Posted: Tue Jul 20, 2010 4:25 pm
If you are experiencing pulsating, vibrating brakes and/or vibrations while driving, a good place to start are the brake caliper sliding pins.
Even if it feels like your tires may be out of balance or the rotors are warped, the sliding pins may just be the culprits.
By design, they will rust and sieze up. It's just the way they are.
So pull them out and check them one by one.
Ideally, you want them to be very smooth with no ridges or rust.
Usually when replacing the brake calipers, if they are a full or partial kit, they should come with the mounting brackets to the spindle and new sliding pins (bolts).
This applies to both L300 front brakes and L400 front/rear brakes.
Re: Pulsating / vibrating brakes - check your sliding pins
Posted: Thu Jul 22, 2010 3:59 pm
by madmazda
Posted: Sat Oct 16, 2010 10:12 am
by pajerry
Does any one know a part number for those? I bent one getting it out and will need to replace it.
Thanks.
Posted: Wed Jul 17, 2013 4:28 am
by mrdueck
Just wondering if anyone has a part number for the pins. I need one for the front and one for the rear on my L400. Are they the same as the Montaro?
Posted: Wed Aug 21, 2013 11:43 pm
by Glenn Delwood
I second the parts question. +1
Also, the one with the sleeve (from the bottom) was missing the sleeve on one of my wheels. It was probably stuck inside. What is it made of and what's its use?
What kind of grease should I use to grease them?
Thank you.
Posted: Thu Aug 22, 2013 2:39 pm
by TardisDeli
Last year I tried to find a caliper bolt for my L300 after the bolt fell out on the highway, I drove (my other vehicle) to every fastener shop in the lower mainland, NO LUCK. I had experts at each place measure it and then phone various suppliers (I verified that each was phoning different suppliers) and I tried Lordco and Princess too. And I got a very nice guy at a delica dealer to unofficially check if the same part was used on any other mitsus in canada or usa, but that part number did not correspond on his canadian database. And I drove the highway where it fell out lotsa times. Ended up getting one from a used delica, but only could get one, so no spares.
This is a problem part. I would be in for a group buy for spare parts. I dont recall the part number, but it was in the russek manual. Cheers Christine.
Posted: Tue Nov 05, 2013 11:31 am
by lrp374
I thought this sounded like good PM. The bottom bolt was easy - took about 5 minutes after the tire came off. I have been looking for the second bolt and am now convinced the picture below shows the 'bolt'. I'm a bit reluctant to tackle taking it out. It appears the little rubber plug may house an allen head bolt but any info I've been able to find suggests it should be just like the bottom bolt. Does anybody else have this 'bolt' as the top slider?
Posted: Tue Nov 05, 2013 2:12 pm
by yojimbo
My memory is that you undo and remove the bottom pin, pivot the caliper on the top pin until the caliper and pads clear the disk, then just slide it off the top pin. It probably is an allen head or such in the top pin, but I dont think you need to undo it with the caliper on.
Posted: Tue Nov 05, 2013 3:20 pm
by nvanadm
yojimbo wrote:My memory is that you undo and remove the bottom pin, pivot the caliper on the top pin until the caliper and pads clear the disk, then just slide it off the top pin. It probably is an allen head or such in the top pin, but I dont think you need to undo it with the caliper on.
Correct. Just did mine last week. Like yojimbo said, undo the bottom bolt, rotate the caliper to clear and just slide it out.
Posted: Tue Nov 05, 2013 8:02 pm
by lrp374
Thanks. It took a couple reads to get through my coconut as I kept thinking I don't want to change pads just grease the sliders.
Larry
