Stripped down VM2, you supply some easy parts, $199
Posted: Tue Jun 08, 2010 3:30 pm
by PlantDrive
Hi all - just wanted to let you know we have a Bare Bones version of the VM2 coolant-heated filter on the site now.
$199 for filter base and O-ring boss (ORB) fittings (3/8"). You add your choice of element (Donaldson P551001 or similar), and port plugs you need for unused sensor ports, and a drain valve or drain plug as needed.
Can be mounted filter-up or filter-down.
We've also added 1/8" NPT ports for vacuum, as well as the ones that were there before for pressure and coolant temperature ports.
(Complete unit with fittings, filter element, filter element insulating cover, port plugs, drain valve is $249)
If you wish, we can also supply 1/2" ORB fittings. Some people like these for the Inlet fitting, if they are using 1/2" line from tank to filter.
When you are not using an in-tank heater, 1/2" line is a good idea.
And, those new valves are almost here (finally!) We should have them in the next few days. $49 for a 3-port valve, Canadian $, we'll have lots of stock in Salmon Arm,
12V or 24V
Thanks!
