94 Delica L400 SPACEGEAR T-Diesel 128k Auto *SOLD*
Posted: Tue Dec 15, 2009 4:28 pm
1994 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, exceed model, Blue with grey color, L400, has 128,000 kms on it.front sunroof & all rear shades work
Automatic, with crystal lite roof, A/C, 7 passenger, 134A AC, fully loaded, will do full B.C.Provincialcompliance, will install New original Mitsubishi headlight E-Code, and full service for this newly designed L400 Delica.New Tire, Radiator, Water Pump, thermosthat, Belt, air filter, fuel, all fluids change , check all brakes, delica L400 tune,new coolant, check stabilizer link if need change, replace water bottle anti freeze, if broken or seen any sign of cracks. this delica is clean.
find the ff on this L400 when it arrived.
1.)absulutely no rust at all.
2.) Check under suspension both lower control arm right & left was been change brand new original mit. sticker attached on it. nearly new change in japan. all bushing on this is like new.
3.) lower & upper balljoint is nearly new replace in japan.
4.) all the steering booth is like new replace in japan.
Vehicle Arrived your welcome to see.:
Stock # PE8W
Any questions please call me:
thanks,
Stock # PE8W
thanks,
