rear sway arm bushings??
- Vehicle: '92 Delica Exceed
I am looking for a part # for the rear sway arm bushings. I have checked almost every corner of the forum and have not come accross it. If anybody knows something, please let me know.
James and Nicole
- wetcoast
Re: rear sway arm bushings??
I needed that part a couple weeks back and called every place in the lower mainland. Only 1 place had the part and I bought the last 2 (suggested to change both).
- Golf Cart
- Vehicle: 1992 Exceed
Mardy has em
- delicat
Or you can also just remove the entire sway bar which has no effects on the driving and gives better articulation and saves you money from not buying those bushings.
But I like Mardy so if you want to keep it he's your best bet as previously suggested.
- Vehicle: '92 Exceed P35W
What was the make & part number so we can xref it?wetcoast wrote:Only 1 place had the part and I bought the last 2 (suggested to change both).
- wetcoast
I wish I knew that info but it never gave with a sticker or anything.Blackberry wrote:What was the make & part number so we can xref it?wetcoast wrote:Only 1 place had the part and I bought the last 2 (suggested to change both).
