Page 1 of 2
looking for block heater for 2.8L
Posted: Sun Oct 04, 2009 12:04 pm
by kglarsen
does anyone know where I can pick up a block heater for a 2.8L engine (Pajero)?
Re: looking for block heater for 2.8L
Posted: Sun Oct 04, 2009 12:14 pm
by flyfishn
Lordco I believe.
Posted: Sun Oct 04, 2009 7:05 pm
by kglarsen
Lordco? Thanks. Any idea what I would ask them for in terms of a vehicle make/model that would mesh with mine?
Posted: Sun Oct 04, 2009 10:01 pm
by Raule Duke
a 38mm "frost plug" should fit
Posted: Sat Oct 10, 2009 6:49 pm
by PHIL
Raule Duke wrote:a 38mm "frost plug" should fit
Everything I've researched says there is no solution for a frost plug heater. The Caterpillar loaders that used the 4M40 (imagine a Caterpillar product with "MITSU-diesel power" on the side! Yeah! Sorry...) used a frost plug heater, but the port they used is blocked by the heater setup in our automotive application of this engine.
I'd love to be proven wrong on this one, but until I am, my large (siliconed in place) engine pad heater works fine, combined with two yellow tops, and factory fuel line heaters.
If someone is able to make it work, please post up the location and bore of the frost plug you used.
Posted: Wed Oct 21, 2009 1:29 am
by pajerry
Is this true? I was going to install one this weekend..
Posted: Wed Oct 21, 2009 7:44 am
by Green1
I wouldn't give up quite yet, the communal wisdom for the L300 up until about 2-3 years ago was that it was impossible to put a block heater in an L300 too, and yet it's common now.
Someone just has to be the brave soul to waste a lot of time (and possibly money) figuring it out, and then it'll be easy for everyone who follows...
Posted: Wed Oct 21, 2009 7:28 pm
by PHIL
Like I said, this is what the research told me, and a look at caps, after finding the right application for the CAT loader etc. This applies to Pajeros of course, but I'd love to find out that there was a way. Don't give up. This is how cross references are built for JDM vehicles - a brave soul proves that something "can be done". :-D
Posted: Sat Oct 24, 2009 1:24 pm
by almac
would not an inline heater be better suited for an L300?
i would think that the circulation of antifreeze in the block would be more efficient.
probably easier to install too...
Posted: Sat Oct 24, 2009 2:00 pm
by Green1
problem is the vast majority of inline heaters don't circulate the coolant, and as a result are useless. I have yet to see a plugin circulating inline coolant heater, though I have heard they exist.
the only circulating heaters I've seen are the Espar and Webasto, but they are both extremely expensive, and somewhat difficult to install.
Posted: Mon Oct 26, 2009 9:46 pm
by Pajero
I just had Japanoid in new west install one for me on my 94 Pajero 2.8l, dont know the details though......
Joe :M
Posted: Mon Dec 07, 2009 2:43 pm
by pajerry
What did they end up charging for the service? Is the service department resonable there?
Posted: Mon Dec 07, 2009 5:20 pm
by pajerry
Pajero wrote:I just had Japanoid in new west install one for me on my 94 Pajero 2.8l, dont know the details though......
Joe :M
Sorry, did you have a block heater or an in line heater installed? If it's in line, does it actually work?
And to everyone else... Has anyone tried the oil pan heating pads that adhear to the bottom? And if so, does it work well and to how low of temperatures??
Thanks.
Posted: Mon Dec 07, 2009 5:22 pm
by Green1
The L400s are now getting actual block heaters... so I suspect the 2.8L paj should be similar... right side rear frost plug I believe...
Posted: Mon Dec 07, 2009 5:59 pm
by DelicaFreaka
kglarsen wrote:does anyone know where I can pick up a block heater for a 2.8L engine (Pajero)?
Here you go. This is all you will need to install your heater. Just did mine and boy is it nice to have with this cold weather we are having in the Interior. Plug it in for a couple of hours and it fires like a dream.........Kirk out.
http://www.delica.ca/forum/l400-4m40-bl ... tml#p50589
