Coolant Change - Winter's approaching...
Posted: Fri Nov 07, 2008 6:01 pm
I just thought I'd chime in on the subject of coolant changes for a moment since it's that time of the year again.
Virtually every JDM I have seen (and many local vehicles too) are running old and under-performing coolant.
A few things need to be noted:
- Please capture and recycle your coolant.
- Replace your coolant every 2 years.
- Long life coolant that lasts for zillions of kms is a fairy tale. Do not for a moment believe that it's going to last for 5 years and 250,000 Kms (just read about GM's problems with OAT coolant technology and DexCool if you don't believe me).
Coolant does many things, but the three main ones are:
1. Corrosion protection. This does not really start until you hit the -36C mark. If you have less than -36C you're going to be making an electrolyte solution out of your coolant. This will cause the various metals in your cooling system to dissolve and plug the system as they precipitate out of solution. Frost plugs will corrode through, head and other gaskets will be eaten up etc... etc... (this is bad, and it's expensive - much more than the cost of coolant changes every two years).
2. Freeze protection. This is obvious.
3. Lubrication for your water pump.
Running water or a weak solution of coolant is very, very bad for your engine and cooling system. Unless you like spending gobs of money on repairs, do not do this.
You should not have less than a 50/50 mix of coolant and distilled water in your system. This does not mean that you simply fill it with 50/50 and you're good. The final test must be 50/50 at a minimum. With a hydrometer, this means you will have -36C or better. Aim for about -45C.
Change your upper and lower rad hoses, and if you have no record of your thermostat being done then you need to do that too. The thermostat is a special one, it has a valve at the bottom that closes against the water neck assembly/water pump. The factory ones are the best quality, but there are others out there that work properly. If you don't have the little valve thingy on your thermostat, you may not get much heat in the car.
Once you have flushed your system, start with adding straight 100% coolant - Universal green is fine.
When you have two jugs in (about 3.8L x 2) then you can top up with distilled water or a 50/50 mix. The system may hold a lot of residual water if you do not pull the block drain plug, and even so there will be lots of water in there.
Install a new rad cap 0.9 Bar (13PSI) when you do a coolant change (Napa part 31333)
Clean out the overflow container, and make sure you top it up to the proper mark with 50/50 mix.
Test run your system and bleed out any air pockets. Have your heat control set to hot, and if you have any rear heaters, set those to hot as well. You should have hot air coming out your heater when you have things bled correctly.
Hope this helps, and if you have any questions, stop in and see your local Delica mechanic.
John
E4 Auto Repair Ltd.
Radd Cruisers 4WD
Duncan, BC
John
E4 Auto Repair Ltd.
Radd Cruisers 4WD
Duncan, BC
