About a month ago I purchased a 1996 L400 turbo diesel. I think it has been in Canada since 2013.
This morning I had a 2.5 inch exhaust installed from flex pipe back with a Dynomax Ultra Flo muffler - drives much better now, lots more power. I will have to get used to not accelerating so hard, before I know it i'm doing 80 in back streets.
This afternoon I removed the intercooler, adjusted the TPS from 1.1v down to 0.85v and installed a boost gauge.
While doing this work I found a wire floating around near the glow plugs. I have searched the forums and had a look at some engine photos but cannot figure out where it is meant to attach. I have included a photo below and hope someone can give me advice on what to do with it.
The boost gauge I installed seems kind of tacky - it is an iEquus Performance 8257. Goes up to 30PSI. Driving around the max boost I see is 9PSI, even if I floor it to 3K RPM up a hill. Does anyone know how accurate these gauges are likely to be?
Thanks for any advice,
Dave in Prince George
