Slow acceleration, sluggish up hills, boost pressure <6psi. Whats wrong?!
Posted: Mon Aug 10, 2015 10:57 pm
Hello all,
I have experienced a 70-80% decrease in power in my van. It starts fine (after 3-4 cranks... not great, but normal for mine) and idles fine but is extremely sluggish up hills and refuses to go above ~3000 rmp. I have a boost gauge installed and it is reading a measly 6psi under load, uphill. I have checked the waste gate and actuator, both are fine. The actuator opens at ~12psi. I thought the problem may be a corroded primer pump or a downstream fuel delivery issue, so I tried bypassing all that by sucking out of a diesel jerry right at the injector pump, but had no improvement. I have purchased a cylinder compression tester to check the cylinder compression (273psi is optimal I believe?) to see if one of my cylinders is dead and therefore not contributing exhaust to spool the turbo... but I am doubtful this is the issue. Basically I am out of tricks. Does anyone have any experience with this issue? Any solutions? could it be the injector pump!? I feel like its something turbo related but I don't know what else to check. I'll try anything!
