ngk glow plugs
Posted: Mon Jun 08, 2015 3:50 pm
by punkrawker
so.....i looked on the ngk website and for a set of 4 ngk plugs part# 2161 is 76.64 plus shipping 35.01 to a town south of calgary is 111.65. this is the cheapest option i have found so far and is less than half of anywhere else i was quoted so i thought i would pass this along to other fellow delica l300 owners.
Re: ngk glow plugs
Posted: Tue Jun 09, 2015 9:40 am
by nxski
I'd be careful with NGK, I put them in my van and they didn't function properly with my ECU, so the van wouldn't start. I tried having the ECU refurbished only to discover it was the plugs, so I wired them into a manual switch, but wished I had bought 12V instead of 6.
Re: ngk glow plugs
Posted: Tue Jun 09, 2015 3:59 pm
by punkrawker
glad you pointed that out. i need the 12v due to previous owner rigging up the manual over ride. i am calling ngk tech department tomorrow and asking if they have the same size plug as the 2161 but in 12v application. i will post my findings when i find out mo info
Re: ngk glow plugs
Posted: Tue Jun 09, 2015 4:43 pm
by nxski
If you have 12V and are just looking to replace them, you should be fine.
Re: ngk glow plugs
Posted: Wed Jun 10, 2015 2:51 pm
by punkrawker
well no luck getting timing down to call ngk before 3pm here but auto valu in calgary can get a set of 2161 ngk glow plugs in for $174.....even if if i only get a few months out of them its better than not driving the van around and almost 100 bucks cheaper than anywhere else too
