I'm planning on putting a lift (2") and bigger tires (31") this spring. What height of bottle jack would I need once this is done? I only have the stock jack and I want to upgrade sometime soon. I saw at Canadian tire they have an assortment, but what is the min-max height I should get?
TIA
Bottle jack
- Vehicle: Delica L400
- Vehicle: 1996 L400 "Yoshi"
Re: Bottle jack
Mine is lifted by 1.5". I kept the stock jack because it fits nicely tucked in the corner. I carry 2 cut off pieces of 2x10 I liberated from a scrap pile at Home Depot. The help raise the height and also give you a stable surface to jack from if it's wet. I also use them sometimes to level the Delica for sleeping.
Re: Bottle jack
Oooo i will stop by home depot tomorrow and ask for scraps
thanks!
thanks!
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Bottle jack
the top pin on my stock hydraulic jack threads out(up/down) to take up height differences found in the road.
you may not even need the wood block if you get an adjustable jack.
Re: Bottle jack
If i can avoid buying another jack i may prefer that :)Big-Bird wrote:the top pin on my stock hydraulic jack threads out(up/down) to take up height differences found in the road.
