WTB EGR blanking plate
- Vehicle: l400
Who is selling them? prefer in BC.
- Firesong
You can check with rising sun. I know they fitted mine with one when I bought the van.
Re: WTB EGR blanking plate
Why you should KEEP the EGR:
http://www.tuneruniversity.com/blog/201 ... you-money/
- Vehicle: l400
that seems like a good resource i will look further into it thx.
Fixed that for you.... article is about gas engines not diesels...Yokohama wrote:Why you should KEEP the EGR ON A GAS MOTOR:
Yes, thank you! That would only apply if the OP has a gas motor.thedjjack wrote:Fixed that for you.... article is about gas engines not diesels...Yokohama wrote:Why you should KEEP the EGR ON A GAS MOTOR:
- konadog
- Vehicle: 1992 GLX L-300
If you don't want the EGR you don't need to put in a blank - simply disconnect the vacuum hose that hose that engages it.
As an addition to Konadog's observation ~ put a machine screw into the end of the vacuum hose when you take it off.konadog wrote:If you don't want the EGR you don't need to put in a blank - simply disconnect the vacuum hose that hose that engages it.
- Vehicle: L300
Frost plug fits perfectly inside the EGR as well.
