Help identifiying component 4d56
Posted: Sat Jun 14, 2014 2:26 am
by sabethedin
Hello
I recently purchased a engine from used from a space gear and need to know what the circled item is in this picture of the injection pump. Any help would be greatly appreciated.
Re: Help identifiying component 4d56
Posted: Sat Jun 14, 2014 10:11 am
by TieMyShoe
if you bought the engine from a spacegear you have yourself a 4m40 from an l400not a l300 4d56.
Posted: Sat Jun 14, 2014 12:58 pm
by sabethedin
Please don't respond unless you can help... You obviously don't know what your talking about. I am absolutly sure what I have is a 4d56T. http://www.auto-data.net/en/?f=showSubM ... li_id=1722
Posted: Sat Jun 14, 2014 2:05 pm
by TieMyShoe
I am not doubting you have a 4d. However it most likely from a starwagon. As for the solenoid. Honestly after your response I am less then interested in assisting you. Good luck on your search though. Perhaps before you act so high and mighty you might try obtaining more then two posts, and getting to know the membership first.
Posted: Sat Jun 14, 2014 11:51 pm
by yojimbo
It could be out of a 2WD L400, oh wait, I'm not sure what I am talking about ;-)
Posted: Sun Jun 15, 2014 1:29 am
by sabethedin
Im sorry you feel that way. Your first reply clearly states that the motor I have is not a 4d56 because it was pulled from l400/Space gear. I simply tried to show that the donor vehicle had multiple engine options, and your second post still doesn't change my opinion of you. My question was for anyone kind enough to share their knowledge regarding the engine. I admit there is very little I can give to this forum. I know next to nothing about these awesome vans other than my engine came from one.
Posted: Sun Jun 15, 2014 8:47 am
by Big-Bird
There are very few 2WD L400 in Canada. That model could have either a gas(2.4L) or diesel(4D56) engine. Most of our membership associate the bigger 4M40 (2.8L TD) in the L400 and the 4D56 (2.5L TD) in the L300 because these are the most common variety we import.
The piece you had asked is a timing solenoid. At least according to the manuals for the 4D56 fuel system. For future queries perhaps a look through the technical manuals would be helpful.
You said yourself you know little about the Delicas....here's a starting point. You can also get a more comprehensive manual on CD from ebay.co.uk for around 7$.
http://www.delica.ca/forum/l-300-fuel-d ... -7339.html
Posted: Sun Jun 15, 2014 9:42 am
by yojimbo
I used to have a link to a pdf for the entire mitsubishi delica manual. But I'd to dig it out and find out it was wrong for the 2wd l400 and id given the OP a bumsteer. I couldnt forgive myself.
