Cold start issue - one click and not turning over?
Posted: Sat Mar 01, 2014 5:38 pm
Hi Delica family,
just wondering if anybody could help spread some insight into my starting issues.
After leaving the van parked for the winter, with a friend firing it up every month or so (with no problems, i'm now back and after replacing the battery still cant get the van to even turn over. It makes its normal two clicking noises, then as i turn the key, i get just one more click and nothing else (sounds like a relay or something)
In the past i think i may have been experiencing problems with my neutral safety switch, as it sometimes didn't like to start in park but preferred neutral or vice-versa.
Is there any way i can confirm it is indeed the neutral safety switch before resigning to waiting and ordering a new part - when it might be something else?
or any way i can just get it to turn over?
I read here about bypassing it http://www.delica.ca/forum/bypass-neutr ... tml#p54084 - would you recommend giving it a try?
Adrian 250 674 7562
Adrian 250 674 7562
