Sup folks??
Just a few questions from a semi newby here....
First, I guess there's no dimmer switch for the dash lights on the '93 Delica Super Exceed?? Not that it really matters but....
Where do you fill the windshield washer fluid on these things?? Winters here in Ontario and she's already getting quite messy. There's salt and sand everywhere!!
Cheers:)
Dimmer switch & windshield washer fluid?
- Vehicle: 1992 Delica
Re: Dimmer switch & windshield washer fluid?
No dimmer switch.
Windshield fluid is in the passenger footwell, just in front of the door, it slides out towards the seat. The rear fluid is under the door, in the door frame surround, not that the rear wash wipe is of a huge amount of use unless you need to see the road in the distance behind you!
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- TardisDeli
No dimmer switch on the Japanese models. There was one on the american version (but it was onl 2 WD, and no bush bar front bumper). FYI, that dimmer switch was located on the blank spot next to cigarette lighter, but no one has created one on this forum, so the wiring probably does not exist.
Regards, CHristine.
Regards, CHristine.
Christine
Thanks folks. I would have never found the washer fill but I'm going out to my van right now to look for it and fills it up!!
Cheers:)
Cheers:)
- Erebus
- Vehicle: 1992 Super Exceed
Because it is a pain to pull out, put in funnel, and pour, I now use a liquid laundry detergent bottle. Squatter and more stable sitting in the van than a normal ww fluid bottle, but it also has a built in funnel!
- konadog
- Vehicle: 1992 GLX L-300
Never had any trouble pulling the washer bottle out at all - maybe a little grease if it's sticky...?
- Erebus
After the first time, I haven't had trouble pulling it out. But the pouring was always an issue until I used the detergent bottle..
It's difficult the first couple of times, but pull on it often enough and it'll come off fine in your hand.Erebus wrote:...it is a pain to pull...
- Vehicle: L300 Starwagon
Haha. Good to know that it pulls out. I thought it was just a really poor design.
...No funnel needed
...No funnel needed
