4wd sender plug
Posted: Sat Jul 28, 2012 11:13 am
So my 4wd light doesn't work, and after a bit of searching I found the culprit. The 4wd sender plug near the transfer case has a broken wire. It's broken right at the plug, so there isn't enough wire to splice them together.
Where can I get a new plug? Actually, there's two plugs and I should replace them both since the wires on the second are also pretty frayed.
