decrease in boost pressure
Posted: Thu Dec 14, 2006 7:47 pm
by lost1
I just noticed that my turbo boost pressure has dropped 5 psi at maximum load. Any suggestions why this happened?
Posted: Sat Dec 16, 2006 11:17 am
by mitch
You boosted your turbo right? not to be a downer, but you think you might have fried a seal or lost compression??? Only a guess hav'nt worked on mine yet
Mitch
Posted: Sun Dec 17, 2006 8:37 pm
by lost1
hope not, its pretty much a standard modification...
Posted: Mon Dec 18, 2006 9:45 pm
by lost1
I may be getting closer. I found a site on the internet that says if the Relief valve (blow off valve) isn't working right, that it can reduce the boost pressure. Don't really know how I can fix this, but I will have a look in the coming days...
Posted: Sat Dec 23, 2006 4:25 am
by VADLEM
could be the relief spring is going soft or a vacum leak in the actuator line
Posted: Sat Dec 23, 2006 1:05 pm
by lost1
Well after cleaning air filter and intake tract, wastegate, and Relief Valve in additiong to jiggling and playing (using a bicycle pump) with the vacuum actuator. I have yet to find the problem.
I will try and have a better look and see if I can find a vacuum leak on the actuator line.
thanks for the advice
Posted: Sat Dec 23, 2006 4:42 pm
by David
How does one notice a drop in turbo boost pressure of 5% under max load?
Posted: Sun Dec 24, 2006 9:36 am
by Chewy
5psi ( lbs per sq. in.) :P with a boost gauge 8)
if there is a leak on the actuator line, you will increase boost. check all of your charge pipes if you already havent, if you know someone with a compressor and a regulator that makes it far easier.
as well, I'm not too sure about Deli's in this sense. but you may want to check that the bolts are tight holding the exhaust manifold to the head and as well the ones that hold the turbo to the manifold, they can back off and you don't even notice the sound change over the usual diesel valve clatter, either that, or the gasket between the mani and the turbo.
