battery replacement?
- Vehicle: 1995 L400 Spacegear Exceed
It looks like my dual batteries need to be replaced on my 1995 L400 and I've been looking around the site for a guide or information on how to do this, but haven't been able to find much other than the recommendations on Oddysey batteries. Are there any pictorial guides or step-by-steps that haven't been able to locate? Thanks.
Re: battery replacement?
the batteries are wired in parallel (12V) so you can remove / install them just as you would a single battery in a standard 12V vehicle.
remove the negative and positive terminals on both batteries
undo the bracket that holds the batteries down
remove the old batteries
install the new batteries
replace the bracket that holds the batteries down
replace the negative and positive terminals on both batteries
- Vehicle: delica L300
Always remove negative terminal first and put negative terminal on last
Dustin
Dustin
thanks a lot for the useful advice.
- MardyDelica
Hi, patton,
used group 24 its the axact battery but get the flat one, ac delco has it also.
pls dont get the 24F as its a reverse post. not right.
only group 24 is th eone u need
cheers
mardy
cheers
mardy
Thanks, Mardy!
- MardyDelica
- Vehicle: L400 (soon)
or to cover off our brits out there........ remove chassis side first (be it negative or positive is irrelevant), quoted statement is correct, just a broader statement to cover off other potential scenarioslegionnair wrote:Always remove negative terminal first and put negative terminal on last
Does the intercooler have to come off to replace the batteries? I can't seem to be able to make space to get the new ones in there.
Patton
Patton
- CREGAN
Just undo the 4 bolts and slide it over to the side, that will make enough clearance.pattonmaclean wrote:Does the intercooler have to come off to replace the batteries? I can't seem to be able to make space to get the new ones in there.
Patton
Craig
Thanks Craig!!
