Whats happend?
Fuses are ok.
NO LIGHTS DASH BOARD LIGHTER CLOCK ????
- L300Foca
- Vehicle: Mitshubishi L300 2.5 TD GLX
- Artacoma
- Vehicle: 97 V6 LWB
Re: NO LIGHTS DASH BOARD LIGHTER CLOCK ????
Check the mess of wiring above your batteries, there is a fusible link in there too.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
When my fusible link went in the battery compartment, it wasn't just the clock that went, it was the cluster lamps, the stereo, I think it was the running lights, too. I wonder how different the wiring on the Euro Delicas is from the JDMs?
- L300Foca
Stereo and lights r ok. As well headlights and starting lamps on dashboard.FalcoColumbarius wrote:When my fusible link went in the battery compartment, it wasn't just the clock that went, it was the cluster lamps, the stereo, I think it was the running lights, too. I wonder how different the wiring on the Euro Delicas is from the JDMs?
Ilumination dashboard lights, lighter and clock r death.
FollowMe
- L300Foca
Fusible link? That is this thing?
Plastic plug
Wire connector
Plastic plug
Wire connector
FollowMe
- Artacoma
Thats it , I replaced mine with a piece of 12guage wire.
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
- TardisDeli
I also suspect the fusible link. There are FOUR wires in it, and yes that is it in the photo. each wire protects a different quarter of the van. Look and see if any of the 4 wires is burnt, or the plastic connector box is cracked or burnt. replace with exactly the same wire size guage wire as you took out. Jay has fixed several delicas with these dying of old age. cheers, christine.
Christine
- L300Foca
tnxTardisDeli wrote:I also suspect the fusible link. There are FOUR wires in it, and yes that is it in the photo. each wire protects a different quarter of the van. Look and see if any of the 4 wires is burnt, or the plastic connector box is cracked or burnt. replace with exactly the same wire size guage wire as you took out. Jay has fixed several delicas with these dying of old age. cheers, christine.
FollowMe
