Rear shackle bushings
Blueberry
Vehicle: Delica Exceed
Post by Blueberry »
Hi. No luck finding p/n in a search.
Does anyone have numbers (or even dimensions) for either OEM rubber or Poly bushings for '93 L300? Energy seems to be easy enough to get - just need the right size. The stock ones are all cracked.
Graeme
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Rear shackle bushings
Post by thedjjack »
If you go into a spring shop they will have something that fits.....I think it was West Coast Spring on the Langley By-Pass I used to rebuild my leaf packs for my 1963 Willys.
If you pull the springs and drop in they will have bushings or turn some....
call John at Rocky Mountain or Mardy at Amazing Auto. I remember both had replaced them at one time in the past.
