HORN RELAY FOR A 92 LWB PAJERO HELP!!!!!!!
92pajero
Vehicle: 92 pajero exceed
Post by 92pajero »
I installed an air horn on the good ole paj and it worked fine for about 2 weeks then all of a sudden nothing. Not even the faint click you hear from under the dash. Anyone know where the horn relay is? Already checked fuses and secondary relay I installed to power the horn. I just cant seem to find the underdash relay. Any help would be greatly appreciated.
Re: HORN RELAY FOR A 92 LWB PAJERO HELP!!!!!!!
Try this file.
You might be overloading the fuse for the horn. It might be drawing more than the stock circuit can deliver.
Fuse_Layouts_2800cc_Pajero.pdf
(52.03 KiB) Downloaded 140 times
Return to “Pajero”
