l400 running then dies
Posted: Sun Feb 06, 2011 6:20 am
by dave1968
l400 delica 1995,just done seal in injector pump,but its still has a problem,it will run for 10 minutes then dies,pump up fuel from filter housing then will run again,as you pump fuel up you can hear something in the tank,like the fuel going back in,somewere its taking air in,or faulty pump,anyone any ideas,
Re: l400 running then dies
Posted: Sun Feb 06, 2011 10:08 am
by Mr. Flibble
dave1968 wrote:l400 delica 1995,just done seal in injector pump,but its still has a problem,it will run for 10 minutes then dies,pump up fuel from filter housing then will run again,as you pump fuel up you can hear something in the tank,like the fuel going back in,somewere its taking air in,or faulty pump,anyone any ideas,
The L400 does pull in more fuel than it needs generally, the fuel return returns diesel back to the main tank.
Any more symptoms? Smoke? It sounds like the fuel pump is not pumping enough diesel, but that is a guess. If you really try revving the engine, does it die?
Posted: Sun Feb 06, 2011 3:34 pm
Check all of your fuel lines from the tank to the filter to the injection pump to to the injectors.
The only way to trace air is to physically run along the lines or disconnect and run compressed air.
Posted: Sun Feb 06, 2011 4:08 pm
by thedjjack
X2 sounds like a leak in the system
Posted: Mon Feb 07, 2011 10:07 am
by dave1968
fitted another fuel filter housing but still the same,but i did notice while manually pumping fuel up by button on top of fuel filter,the fuel is going into the pump coming back through the return pipe back to the tank,i dont think that is meant to happen,
Posted: Mon Feb 07, 2011 4:38 pm
by dave1968
and what is the solenoid on the back of the pump for,green cap,on the return pipe,
Posted: Thu Feb 10, 2011 8:50 pm
by Kuan
Hi,
Did you get your issue resolved? Just curious as my van has similar symptoms although it only occurs when its cold and the van is not warm. It happens at about 1.5-2km from home on a cold day. But it only happens the once when the van is not warmed up yet.
So that means it should be somewhere that a seal is shrinking with the cold but then when warmed up seals again....maybe?
Posted: Thu Feb 10, 2011 9:13 pm
by deli1733
My pajero has the exact same symptoms and on monday its going in finally to get the front seal on the injection pump replaced, so I'll let you know how it went for me when i get it back.
Posted: Thu Feb 10, 2011 10:32 pm
by DelicaMark
These guys are working on the same issue.
http://www.mdocuk.co.uk/forums/viewtopic.php?t=35523
This seems better:
problem solved. yahoo! apparently there's a small gauze filter inside the stop solenoid on the fuel return. yip,it was blocked.no fuel return to tank from pump. hats off to my dad. 74 years old 50 yrs as a diesel plant and forklift fitter.
komatsu use the same on their pumps. there's also 4 small 0.6 mm holes around the solenoid where it fits into the banjo.
so, all new fuel lines,new filter, tank drained and cleaned,particle filter removed from tank,and it was what he said in the beginning. see,no matter how old you are,you think you know more than your parents, common fault on forktucks. happy days,and thanks to all for your help:)
Taken from here http://www.mdocuk.co.uk/forums/viewtopi ... 80&start=0
Another reminder about the amount of info on the uk site compared to here for the L400.
-Mark
Posted: Sat Feb 12, 2011 2:12 pm
by dave1968
ive just taken off the return and feed that are attached to the pump,they both go to the same pipe,return and fuel from filter,but there is a solenoid which bolts the pipe to the pump,it has a 0 ring,rubber on it,it could be that or the solenoid,its not the fuel shut off,it has a hole in it,but really need some pics of the solenoid as it may have something missing,so if anyone has any pics,could they put links on here please,
