Page 23 of 26
Re: L300 Stretch updates
Posted: Fri Oct 25, 2013 10:13 am
by Rattlenbang
konadog wrote:
Rattlenbang wrote:I think that's why our temp gauges rarely rise above 1/4.
:? My temp gauge displays 1/2 when running normally...
My rad is likely newer than yours. 8-)
From what I've read on here, low readings are common. I even blocked half my rad with cardboard to help warm it up faster since I run on WVO, and made no difference. I have to climb the 'hat with that cardboard in there to get to 1/2. Even in the summer.
Posted: Fri Oct 25, 2013 3:48 pm
by konadog
Different rads, perhaps, or different gauges... My rad was replaced when the bus was first refit after it arrived in Canada but that's all I know about it. The gauge is stock. Maybe there is a range in the calibration of the gauges where yours reads 1/4 at the same temperature that mine reads 1/2.
Anyway - sorry for the sidetrack highjack.
Things are looking good with the Stretch project. Milestone stuff getting the mill installed.
Posted: Fri Oct 25, 2013 3:55 pm
by glenn
Mine always reads at 1/4 or below. I've changed rads, thermostats, and pretty much everything else on the cooling system and I can never get it above 1/4. I know this is the case with others too, and my mechanics never bat an eye at this.
Posted: Fri Oct 25, 2013 4:13 pm
by Super Exceeded
8-) 8-) 8-) 8-) That's right Biatches!!!!!! It's IN!!!!!
Posted: Fri Oct 25, 2013 4:15 pm
by Super Exceeded
What does this van have that's a little different? She's got a Chevy 350 under the bonnet 8-)
Posted: Fri Oct 25, 2013 8:10 pm
by Rattlenbang
I heard that the Lexus V8 was supposed to swap in easy. Any reason why you didn't go that route?
Posted: Fri Oct 25, 2013 8:15 pm
by Super Exceeded
Parts availability for one, second, I wanted an engine with a little electronics as possible. A lot less can go wrong in the bushes if there are no electronic gremlins waiting around the corner.
Posted: Sat Oct 26, 2013 9:07 am
by thedjjack
there really is no better motor than a Chev small block...I have seen them turn 8,500rpm every shift for years.....
plus a rebuild cost nothing.... push rod V8 designed motors simple and effective
I cannot wait to see this thing lighting up 6 tires.... You might need more glue where the two trucks are joined.....
Personally I like fuel injection but a carb is nice if the fuel is questionable quality..
Road trip to Port McNeill?
Posted: Sat Oct 26, 2013 9:25 am
by Super Exceeded
Of course! :)
Posted: Wed Oct 30, 2013 4:38 pm
by Super Exceeded
Brought her home today (to KGA) to get the wiring and plumbing sorted out. Check out the wheel flex.
Posted: Wed Oct 30, 2013 6:06 pm
by thedjjack
where are the airplanes....
I cannot wait to see this thing running again
Posted: Wed Oct 30, 2013 11:42 pm
by Super Exceeded
LOL there is one plane behind the truck and one other was pulled out so I had room to get the truck in.
Posted: Thu Oct 31, 2013 8:27 pm
That is one skucum looking land ship you have there, Arnold! Great articulation with the rear trucks. Keep up the good work... smiles.
Posted: Mon Nov 04, 2013 7:40 pm
by TieMyShoe
I can't help but think a Duramax woulda been cool to lol. Look forward to seeing this thing done.
Posted: Mon Dec 23, 2013 12:15 am
by thedjjack
updates???
