Page 2 of 2
Re: Provent oil catch can
Posted: Wed Jan 19, 2011 1:20 pm
by delicat
Good work Sergiy, thanks for posting! Nothing like keeping your pipes clean!
Posted: Sat Mar 19, 2011 5:52 pm
by Pajerist
madmazda wrote:I've made one out of copper fittings and a k&n filter on top... now to just find room to mount it
please post pics!
Posted: Sat Mar 19, 2011 5:53 pm
by Pajerist
Strada 92 wrote:Strada-Caster,really interested by your catch can.
Do you have some picture?
Thanks.
Same here! Please post pics/share you results...
Posted: Sat Mar 19, 2011 5:59 pm
by Pajerist
mararmeisto wrote:Same reason there is a paper filter in the air intake pipe.
Paul, how metal elements in your catch can do the job of paper filter? Have you noticed performance improvement? How often do you drain oil from the can?
Thanks,
Posted: Sun Mar 20, 2011 5:04 am
by Strada 92
I've installed a Provent 200 catch can on my Strada.Truly effective.Not a lot of oil,enough to wipe with a rag once a month.The rest of oil is trapped into the little filter inside of the Provent. But there is a bit more water coming from the condensation of cold air
entering the engine thru the intercooler at low outdoor temperature.Mostly,it's a litlle piece of ice that i remove.
I wanted the systeme to be closed,not open to air and I do not want to return this crap in the oil pan so I plugged the small drain tube and clean the Provent once a month.
