way too high fuel consumption: the beginning
Re: way too high fuel consumption: the beginning
pascal wrote:
jfarsang wrote:Unbolt/remove the front driveshaft as a test to see if the transfercase is engaging 4x4 on its own (which it shouldn't be).
Make sure that you have an oil pan nearby. When you take front drive shaft off, the transfer case empties. No joke. I just did it and had to call a friend to get him to bring me some Gear Box oil ASAP so I can get the van out of there.
don't pull out the yoke and this is not for racing down the road at speed. It's a test to move forward/backward to see if the transfercase is engaging or not. If you pull out the yoke from the transfer case output cone, it will leak.
