Page 2 of 2
Re: Pyrometer Probe Installation Question
Posted: Mon Mar 15, 2010 1:20 pm
by tonydca
Green1 wrote:
mararmeisto wrote:Because the temperatures are over 100 degrees C, it's probably a thermocouple rather than a thermistor.
What makes you say that? the engine temperature sensors are thermisters.
Also when searching for information on pyrometers, all the stuff I found talked about thermisters, not thermocouples.
I agree completely; if it is a thermistor, no problemo.
If a thermocouple, make sure you have the proper extension cable material.
Just know b4 you cut&splice; that's all!
Posted: Mon Mar 15, 2010 1:23 pm
by mararmeisto
Engine temperature sensors are generally located in the cooling water, and since one doesn't want the water to boil, it's okay to use a thermistor. Linear response above 100 C is not always acheivable, so thermocouples are used. This is one of the sources I found regarding this information: http://www.process-controls.com/enercor ... s_rtds.htm
Posted: Mon Mar 15, 2010 1:52 pm
by Green1
Interesting, I had actually been looking for that sort of information but had not been able to find it... (apparently my google skills are weak at the moment...)
Given that information, you're probably right, must be a thermocouple, and yes, in those cases the leads could be relevant.
Posted: Mon Mar 15, 2010 2:20 pm
by mararmeisto
Green1 wrote:Interesting, I had actually been looking for that sort of information but had not been able to find it... (apparently my google skills are weak at the moment...)
As a level-12 Google Mage, it's not a so much a matter of what one googles as much as how one googles. One must know what one is looking for - a matter of knowing the question before asking it. Only then will one find the answers one seeks.
Posted: Wed Mar 17, 2010 11:55 am
by norisan
Just talked to tech help at Shiftglow Gauges and they say increasing the length of the probe wiring will not affect the gauge accuracy. Can't speak for other manufacturers.
Posted: Fri Mar 19, 2010 8:12 pm
by Jsq
EnviroImports.com wrote:why not just take off your egr valve and put the pyro probe in the new plate, then you get a great double duty, get rid of the black smoke monster and put in a pyrometer.
Am I correct in thinking that the EGR is connected pre-turbo? If so that would help me greatly as I want to install my pyrometer pre-turbo rather than downstream.
Posted: Fri Mar 19, 2010 8:30 pm
by jwfchase
Jsq wrote:Am I correct in thinking that the EGR is connected pre-turbo? If so that would help me greatly as I want to install my pyrometer pre-turbo rather than downstream.
You are correct.
