does anyone know if the north American model's Master cylinder will cross over to the JDM's?
also seems as tough there are two center bores 7/8" or 15/16" any idea which ours is?
cheers
CJ
Master Cylinder
- Raule Duke
- Vehicle: 92 Pajero SWB
Master Cylinder
"There's a uh, big machine in the sky, some kind of, I dunno, electric snake, coming straight at us!"
lopar
- Vehicle: L400 (soon)
Re: Master Cylinder
Brake or Clutch?Raule Duke wrote:Master cylinder
- Rising Sun Auto Import
Re: Master Cylinder
It seems he is talking about brake master cylinder.Raule Duke wrote:does anyone know if the north American model's Master cylinder will cross over to the JDM's?
cheers
CJ
If that is the case,15/16" is correct and I don't think there are part crossover in NA cars.
You may get a used one or new one from Mitsubishi ( over $400 I guess ).
Of course some manufacturers in China supply them at cheap price.
Steven
- Raule Duke
lopar
Re: Master Cylinder
Most hydraulic systems have some form, or variation, of a master cylinder and slave cylinder. The master cylinder controls the slave cylinder (as implied in their names) usually to achieve either power or increase in range of motion.Raule Duke wrote:(isn't the slave cylinder the clutch?)
lopar
Re: Master Cylinder
Artie Fufkin
- Vehicle: Pajero
Re: Master Cylinder
this thread would make more sense if I knew what a master cylinder was ..
AF
AF
- Raule Duke
Re: Master Cylinder
It's the 6inch or so long metal thing below the brake fluid reservoir that is mounted to the break booster.
It is where the mechanical movement from your foot is turned to hydraulic power
- newMC.gif (84.89 KiB) Viewed 4442 times
