Spare Tire Fit
Bessie the Mud Slayer
Vehicle: 93 Exceed.
Spare Tire Fit
Post by Bessie the Mud Slayer »
Hey all,
Recently had to get a new spare tire (long story) and the new one is a little too snug. It's stock size, same size as all others, however its perhaps a little too fat. Can't seem to get it to fit. So, short of getting a different tire, or a roof basket, I was thinking of modifying the basket for the spare. Adding about 3/4 - 1" to the length the basket hangs down. Any of you think of any possible problems with this?
Yokohama
Re: Spare Tire Fit
Post by Yokohama »
Have you checked to see if the tire shop over-inflated the tire, and hence made it not able to fit?
Also, maybe because it is new, the fit will be a little tight. Maybe the factory one was this way when new.
Re: Spare Tire Fit
I run my tyres at 42PSI but the spare will only fit if I have it at 33PSI. Good to keep a compressor with you in the event you need to use it.
Vehicle: 93 Exceed.
Re: Spare Tire Fit
I've taken the spare down to 20psi, and its still tight. Proceeding with adding 1" to the basket.
Re: Spare Tire Fit
Out of curiosity, Bessie ~ What size tyres are you running? When you say "stock size" that is 215SR15 (215/85R15). I'm using 235/75R15s, for reference to my previous post.
yojimbo
Re: Spare Tire Fit
Post by yojimbo »
Fwiw I have trouble fitting my spare tire in the van. But I promise to eat better and lose a few pounds.
1994 L300 Jasper
1986 Scimitar 1.8Ti
Erebus
Vehicle: 1992 Super Exceed
Re: Spare Tire Fit
Post by Erebus »
Sorry I didn't see this post a long time ago. I also had the issue of my 235/75/r15 tires. I modified the carrier by drilling another hole in the vertical part.
See my old post at http://www.delica.ca/forum/spare-tire-c ... tml#p10787
Erebus
