Hey!
Spring is here and it's time to change my fuel filter.
I researched the process and quickly saw that I don' t have the tools to do this.
I'm wondering if any toon members can recommend a place in town to get this done. I thought I would do it when I change oil and get seasonal fluid checks.
Thanks in advance!
Patton
Fuel filter replacement- Saskatoon
- Vehicle: 1995 L400 Spacegear Exceed
- CREGAN
Re: Fuel filter replacement- Saskatoon
Fuel filter replacement is way easier than you think, and it doesn't require much in the way of tools. There is step by step here on the forum somewhere ( I think it is in a thread about Seafoam). Just do a search and you will find it. I used it and it all worked out. It can be a little messy though.
Craig
Craig
- CREGAN
- Firesong
I can give you a hand. Super easy.
Thanks firesong!
I contacted manitoba deli about doing some work on it, but will be out of the country when he passes through town. I'll give you a shout when I get back!
Patton
Patton
- Vehicle: 1994 Pajero 2800 LWB
The little primer pump on the filter housing makes our fuel filters a breeze to change. I've never had an easier time bleeding a new filter on any other diesel.
