Delica battery
Posted: Mon Dec 30, 2013 9:09 pm
by andrewbergen123
Help! -34c In Winnipeg. I have a 94 Delica super exceed 2.8l diesel.
I NEED A NEW BATTERY. WHAT KIND OF BATTERY DOES IT TAKE?
Thanks in advance!!
Andrew
Re: Delica battery
Posted: Mon Dec 30, 2013 10:45 pm
by CREGAN
I bought 2 Motomaster Eliminators group 24 at CT for 283.24 with the trade in. The product code is 01024868. They work great in this F-ing cold.
Craig
Re: Delica battery
Posted: Tue Dec 31, 2013 8:21 am
by VanVonVan
Get the biggest cold cranking amp (CCA) you can. I think mine are 800CCA. Especially in this wonder -50 weather(with the wind), Do you have 2 batteries in your deli? I found it was a little shuddery this morning at start up even after being plugged in.
Re: Delica battery
Posted: Tue Dec 31, 2013 10:07 am
by mark
I just replaced batteries in my 1994 L400 Super Exceed this past weekend. Mine is a 2-battery (winter package) system, and the batteries that I installed are the Best Buy BB24 obtained from Vancouver Auto Parts (VAP) in Richmond, BC.
Replacement ended up being a bit of a hassle, because the first set of BB24s that I picked up from VAP were mislabelled - they were actually BB24-F's meaning that the +'ve and -'ve terminals were reversed. When I returned to the store to exchange, the staff discovered that their entire batch had been mislabelled except for one unit (and I needed two).
Moral of story... When purchasing batteries, remember to visually confirm that +'ve and -'ve are in correct position (labels can be wrong)
Re: Delica battery
Posted: Tue Dec 31, 2013 5:25 pm
by andrewbergen123
Thank you for the replies. I only have one battery. I would like to have two. It doesn't look like there is lot of room in there. There must be some conversion done to fit it in? So the single battery would be a group 24?
Re: Delica battery
Posted: Tue Dec 31, 2013 5:52 pm
by mark
The
1997 Spacegear Manual at page 34 recommends battery dimensions of 300mm (length), 174mm (width), and 220mm (height).
Those dimensions are reasonably close (but not
exactly the same as) a Group 24 battery which would be 260mm (length), 173mm (width), and 225mm (height) - see
http://www.evdl.org/pages/bcigroup.html)
I know first-hand that Group 24's will fit in the case of dual-battery 1994 L400. However, before buying it would be reassuring to get confirmation from an owner of a single-battery L400.
Re: Delica battery
Posted: Tue Dec 31, 2013 9:10 pm
by andrewbergen123
Again thank you thank you. Big help you guys!!
Re: Delica battery
Posted: Wed Jan 01, 2014 5:30 am
by fredt
Re: Delica battery
Posted: Wed Jan 01, 2014 2:21 pm
by almac
I went all out when I replaced my pair.
I replaced my duels with a single odyssey. I think it was a pc1800.
can't recall the model#, but its' a fantastic battery.
Re: Delica battery
Posted: Fri Jan 03, 2014 9:35 am
by mrdueck
I have heard from a number of automotive battery pro's that one big battery can not match two small one's. I got my at Walmart, 3yr replacement warrenty. The van is gone right now so I can't confirm the size but I do recall that I ended up with slightly shorter batteries (height) than the stock one's. Both where 800CC. They have been working well for me here in Winterpeg.
Rudy
Re: Delica battery
Posted: Mon Jan 06, 2014 1:21 pm
by MardyDelica
hi, battery size you need for single battery is group 27 same as the 1984 Toyota landcruiser.
the post terminal were all the same
hope this help
cheers
