Hi all - just wanted to let you know we have a Bare Bones version of the VM2 coolant-heated filter on the site now.
$199 for filter base and O-ring boss (ORB) fittings (3/8"). You add your choice of element (Donaldson P551001 or similar), and port plugs you need for unused sensor ports, and a drain valve or drain plug as needed.
Can be mounted filter-up or filter-down.
We've also added 1/8" NPT ports for vacuum, as well as the ones that were there before for pressure and coolant temperature ports.
(Complete unit with fittings, filter element, filter element insulating cover, port plugs, drain valve is $249)
If you wish, we can also supply 1/2" ORB fittings. Some people like these for the Inlet fitting, if they are using 1/2" line from tank to filter.
When you are not using an in-tank heater, 1/2" line is a good idea.
And, those new valves are almost here (finally!) We should have them in the next few days. $49 for a 3-port valve, Canadian $, we'll have lots of stock in Salmon Arm,
12V or 24V
Thanks!
Stripped down VM2, you supply some easy parts, $199
- Vehicle: 1991 Delica
Post by PlantDrive »
Edward Beggs
PlantDrive.ca
Salmon Arm BC
plantdrive.ca@gmail.com
PlantDrive.ca
Salmon Arm BC
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
