				Horn issues
				Posted: Thu Jan 20, 2011 7:25 pm
				by delidemon
				So I picked up my new Delica and I am getting it ready for the OOP and I can't seem to get the horn to work.  Tried swapping the fuses with no luck and now I am trying to find the wiring issues.
Anyone with experience or ideas?
Thanks,
Don
				Re: Horn issues
				Posted: Thu Jan 20, 2011 8:24 pm
				by busrida
				Mine died on me just the other day.  The fuse is fine so I'm assuming the actualhorn either got wet in the snow or just died. Either way I picked up an air horn tonight so if it's wiring I'll let you know after the weekend.
				Re: Horn issues
				Posted: Fri Jan 21, 2011 12:19 am
				Have you checked the connexion in the steering wheel?
				Re: Horn issues
				Posted: Fri Jan 21, 2011 12:27 am
				by Golf Cart
				Pop the leads off the horn itself and see if you are getting juice to it. If not then I would check the connection at the steering wheel.
				Posted: Fri Jan 21, 2011 8:18 am
				by delidemon
				Thanks for the ideas. That will be today's plan.
				Re: Horn issues
				Posted: Fri Jan 21, 2011 7:34 pm
				by busrida
				Not to hijack your thread... But I figured we could share your horn thread.  ;)
Replaced the interior fuse this evening, hit the horn and it worked.  When I tried it again it was dead with another blown fuse.  I assume (correct where necessary) this would indicate a short somewhere between the steering wheel and the interior fusebox.   What colours are the horn wires?  I'd really like to get this cleared up tomorrow.
Thanks.
				Re: Horn issues
				Posted: Mon May 30, 2011 12:01 pm
				by nxski
				What was the result of this?  Is it a stock steering wheel?  I had a problem getting mine to work with my new steering wheel as there was no connection point for the ground wire. I ended up taping the ground wire to the interior or the hub adaptor and problem solved.
