1993 P35W Delica for sale in Courtenay BC $12000
Posted: Wed Sep 22, 2010 2:26 pm
				1993 Delica P35W for sale in Courtenay BC.178000 kms. In fantastic condition.  Imported & serviced by Coombs Country Auto, it has been cared for by the best mechanics. High roof, 7 passenger model (bench seat in middle) easily converts to a bed. Interior in great condition. Exterior also great - just had body work done to remove 2 small rust spots and some key scratches. New speakers and stereo, CD, USB & Ipod jack. Runs perfectly, we're sad to part with it, but need to upgrade to the 8 passenger model for a growing family (twins!) Call 250-898-8590 or email thenickersons@shaw.ca
The following work was done by CCA since importing last year ($5500 in receipts)
Engine serviced and the following replaced:
timing belt, balance belt and drive belt set
timing belt tensioner set
front engine oil seal set
water pump
valve cover gasket set
thermostat
rad cap
upper and lower rad hoses
reconditioned rad replaced
antifreeze
new battery
new lights to meet North American standards
oil, air and fuel filters replaced
Underbody serviced and following replaced:
inner/outer tie rod ends
steering rack boots
front brake rotors, pads, calipers and shock absorbers
front sway bar bushes
rear sway bar links
All engine and tranny mounts replaced
windshield seals replaced
tires replaced, balanced and front alignment
water pump
thermostat
rad cap
antifreeze
new battery
steering rack boots
rear sway bar links
